Es kann eine etwas schwächere Bremswirkung geben, wenn die Batterie über 85% ist, aber ansonsten denke ich, dass es das gleiche ist (google translate :))
Beiträge von Mizuno
Picture showing charging in 0 degrees Celsius after driving for 90 I'm mostly highway 100kmh. It's 18 kwh and battery was on first white line, so not cold or warm. It's vary bad and I send email to Mazda this morning and ask för answers regarding battery warming.
21 ° C or 21 ° F? 21 ° C is like hellfire: evil:
Celsius ?
Yesterday I tested 100 km / h gps speed for 60 km and consumption was 22.7 kwh, on the way back 110 km / h and then it will be 25.2 kwh. Outside temperature around 0, inside the car 21, cruise control on. it is the same result as before the update because The update had nothing to do with efficiency ?.
I received an update on December 22 and the only major difference is that the car reports correctly when charging is completed. average consumption is within the margin of error and DC charging is slower but it may be due to other factors.
I have a theory without any evidence ?. in the instruction manual you can see a picture where it says PTC heater which would mean that we have both PTC and heat pump. PTC is much faster to develop heat and probably comes first to help the heat pump achieve a certain amount of heat in the cabin. After that, the PTC is turned off to save energy and then we experience a different type of heating. Just a theory. Attach image from manual.
Some modern EVs have automatic battery heating when you choose to navigate to the DC charging station. There is a huge difference in charging speed between hot and cold battery. It would have been a good solution or let us put the heat on ourselves.
Today was 3 degrease outside, I get 15kwh. I am not sure if other car connected to AC it's the problem?
Update does not help with charging speed, with me it is actually worse but it may be due to the weather. I got around 22kwh at 50 kwh CCS
Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. [attach = '478', 'none', 'true'] [/ attach] there does not have to be a problem with the steering because this is what it looks like if you press the power button without keeping the brake pedal depressed. attach picture of my car.
