@SE-Hintzu
Does your WB has load balancing? Perhaps there are other heavy electricity consumers switched on during charging. You could try to set the charge rate at 10A (if possible) and see if the problem persists.
After charging the heater of high voltage battery could drain the battery and start a new charge session.
